  • 13 Replies
  • 3377 Views
jeffvdp
I am using Windows 10. I am trying to sign in to my.arlo.com to subscribe now that my free trial ends today. I consistently get a "request timed out" error on both Edge and Chrome.
13 REPLIES 13
Is the two factor authentication timing out?  Or something else?
jeffvdp
It happens after I put in email and password.
Are you seeing a red stripe at the top that says "Authentication timed-out. Try again."
Or something else?
jeffvdp
It is red momentarily, but then becomes an orange bar that says "Request timed out"
What is the text in the red bar???
Are you then seeing an option to choose another verification method at the bottom center of the screen?
Dg_in_FL
Same thing here. MacOS. "Request timed out" Can't log in.
Looks like a long-running problem with Arlo that the company has been unable or unwilling to solve.
ShayneS
@Dg_in_FL
Which version of Mac OS are you running? I can not replicate this with Sonoma 14.2.1 (23C71)
Do you happen to have a screenshot?
jeffvdp
I don't know if there is text in the red bar or not. It happens for only a moment. There is no option for selecting another verification method on the bottom of the screen.
ShayneS
@jeffvdp
Thanks for the update. Were you able to subscribe to your plan?
jeffvdp
I am able to sign up with my phone, but it still would not work on either of our desktop PCs with Edge or Chrome.
ShayneS
@jeffvdp
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to the Profile icon > Support Center > Select device > contact
Dg_in_FL
My desktop is MacOS 12.7.3
I'm able to log-in though my iPhone but not able to log-in with the desktop, as the OP is also experiencing.
I also receive a flash of a red bar across the top of my browser that is immediately replaced by a yellow one.
The red bar says "No Internet Connection"
The yellow bar says "The request timed out"
Since multiple users on different platforms are getting the same errors, the problem is almost certainly on Arlo's end.
ShayneS
Hi,
Are we still experiencing this issue logging in to the browser?
  • 13 Replies
  • 3378 Views
