Hello,
Are Pro 4 XL cameras discontinued?
What year were Pro 4 XL released?
Would Pro 4 XL cameras be considered an upgrade from Essential 2 XL 2nd generation?
2021
Arlo hasn't said, but they are not currently listing them in the Arlo store. I am not seeing any new Pro 4 cameras on Amazon or Bestbuy either.
So I suspect they have been discontinued. The Pro 5s is very similar, so it isn't surprising that they are no longer selling the Pro 3 or Pro 4.
FWIW, discontinuing sales does NOT mean that the cameras are not supported.
Hard to say.
Both are 2K cameras. Some of the differences (no particular order) are
- the Pro 4 can be paired with a smarthub.
- the Pro 4 has a user-replaceable battery
- The Pro 4 can use either a magnetic or screw-thread mount
- The Pro 4 has a wider field of view (160 degrees vs 130 for the Gen 2).
- The Gen 2 has a USB-C port for charging, the Pro 4 uses a proprietary connector
- The Gen 2 cameras are much less expensive
Arlo says they will be adding smarthub support to the Gen 2 cameras (hopefully soon).
2021
Hard to say.
Thank you. This is helpful information.
Thank you so much for the information.
Arlo Pro 4
labels
Samsung SmartThings
