None of my cameras or doorbell is working even after the website stated the outage is resolved. I can only do live view and it is not showing a new recordings for a few hours. Does any one else have this issue still? I’m located in the north east.
Some additional fixes have been made. You may have to log out of the app and back in but this issue should now be resolved.
Are you getting notifications saying the cameras have been triggered? Have there been new events triggered that you expect to be visible within the library?
Yes , there have been several events since 1 pm that should have triggered motion. I’m speaking with other people across the country having the same issue still as well
James, do you know if arlo is still working to resolve the issue with the remaining customers still affected?
Yes, we're continuing to investigate these reports. Consider rebooting your Cameras/Base Station/SmartHub and test again to see if you still experience the same behavior.
Hi James,
Thank you for investigating, I tried everything to no avail. Hoping the issue is resolved by sunset here
Rebooting one of my bases, and restarting the app had no effect for me. All devices show off-line, and the smarthub LED status is blue.
My cameras are working again thank you!
I understand that there was a service outage several hours ago and my cameras did start working again after that was resolved, but they have stopped working again and have now been down for several hours. I have multiple models of camera, some connected to a base station and others directly connected to the internet. I also have a wired video doorbell. All show offline in the app on multiple devices as well as showing offline in the web portal. I have rebooted all my cameras and the base station three times now.
To add a datapoint - I tried factory resetting one of my cameras that does not rely on a base station (an Arlo Q Plus) and removed it from my app. I was able to easily enroll the camera again using the Add New Device button, it was detected, and added. However, it IMMEDIATELY then showed as offline just like the rest of my cameras, lights, and doorbell.
Our cameras have been down for about 9 hours, doing the same as you describe, it started with no notifications coming through now they won’t even live view even though there saying connected i reset one camera now its completely not working, rang support the second time they got very angry at me what a joke, hope we get a month of our subscription
W8,
What is the LED behavior on your base station? Are your cameras showing offline?
Arlo Pro 4
labels
Samsung SmartThings
