Switch on a specific camera?
  • 2417 Views
Bjoelsson
I want to be able to switch on specific cameras not all at once how do I do that?
https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
https://kb.arlo.com/4900/How-can-I-set-a-schedule-for-my-camera-in-my-Arlo-account
Note that these are for the old user interface (UI). If you have the new one that uses Feed to view videos, click on the link near the top of each article.
Lemonchick
If you are using the app on your phone, all you have to do is click on the three little dots on each camera's view, select "device on" and then tap on "device off". That will switch it on. Back out with the arrows. To turn off, just do the same thing, only you'll tap on "device on" and it'll turn it off.
I have Pro 3 and Pro 4 cameras. Hope that helps.
Bjoelsson
Thanks it work👍
  • 2418 Views
