  • 5 Replies
  • 1280 Views
ATX19913
Got system setup with 3 cameras, things were going well with motion detection for a few days, then the motion detection capability stopped working on all 3 cameras.
I ran the diagnostics for motion detection and the light blinks when ran on each light.  Adjusted sensitivity to max, but no detection occures.  Read forum discussions but nothing seems to work.
VERY FRUSTRATED
It sounds like you are saying that the motion detection test did work, but you are not getting motion notifications or recordings.
One thing that trips people up - the threshold you set in the motion detection test is only for the test.  It's not saved or used operationally.  The process for that is outlined here:
A couple of other things to check:
  1. Are the cameras armed?
  2. Can you livestream the cameras?
  3. Can you make a manual recording while livestreaming?
5 REPLIES 5
ATX19913
Yes Cameras are armed.
Yes I can livestream
Yes I created a manual capture
Did you change the threshold in the camera rule(s) when you set it to max?
ATX19913
Not sure what you mean by changing the camera threshhold.
I did go ahead and removed the zones.
The motion threshold
The test is just a test, it doesn't change the threshold that the camera uses.
  • 5 Replies
  • 1281 Views
