One of my Arlo Pro 4 cameras has stopped transmitting. I have charged it, put a different battery in and still no transmission. I removed the device and attempted to add it back and it cannot be found. The blue light blinks and it reads the QR code to start to find it, the blue light blinks a few seconds and then a gold light blinks a few seconds and it turns off. Basically it is useless. Any ideas. Thanks in advance.
It appears that the camera in question will not reconnect directly to the wifi router. There are 4 other cameras currently connected on the router. Additionally I have 4 other older models connected through a smart hub. I was able to connect the camera in question through the smart hub and it is now functioning through that.
Have you reset the camera?
https://kb.arlo.com/000062438/How-do-I-factory-reset-and-re-sync-my-Arlo-camera
Have the same model and the same problem today! I reset all my cameras yesterday, lot of problem since end of last year, very dispointing with Arlo...If anyone has a solution?
I tried resetting it several times to no avail. I have several older models that run through a base station. I was able to connect it through the base station so it is working through that.
Do you have a mesh network an individual wifi bands active? Did you happen to make any network changes with the SSID or password?
These cams are all connected directly to your router correct?
Thank you for the update.
Yes from my side, the are directly connected to the router.
@Greg1806
Is this issue still occurring now?
Arlo Pro 4
labels
Samsung SmartThings
