The first 3 months with the complimentary cloud storage was flawless.
I was unable enable the "RECORD LOCALLY" button in the iOS app, which I could during the first 3 months.
How is that so? Must I subscribe to record the files locally?
Recent firmware releases for the Arlo Base Station/SmartHub have fixed bugs that resulted in this issue. If you're still experiencing issues with local storage, please open a new thread here in the community.
For more information on local storage and the minimum requirements, take a look here: How do I set up local storage backups on a USB device using my Arlo base station?
karlckloh,
When you say you were unable to enable this. What exactly are you experiencing? Do you see any error messages?
I’m getting the following error message when I enter “Storage Settings” from the iOS app.
Local Storage: Error SD card < 16 GB
Available Storage 163.71MB used of 19...
Does that mean that you are using a card < 16 GB?
Recent messages suggest that there has been a change and the local storage fails with cards smaller than 16 GB. (I can't find the messages thanks to the hopeless search tool.)
If so, do you have a bigger card you can try?
Just another user
Hello, I’m a french user of ARLO PRO 3 and I Have exactly the same problem. All was working perfectly but one day no more local record and the same message as yours on card capacity. I’m still waiting a proper answer from ARLO, they told me that engineer are advised.
ChrisP33,
What capacity is the storage device you're using?
Hi, when all were working, I used a 500Go flash disk and now I have tried with a 128Go USB key, 64Go SD Card and the IOS software always indicate an error : SD CARD < 16Gb.
HI, same date no more local record after 3/31/2020.
The error message was showing < 16GB, yet at the page it’s showing available storage of 190+GB...
I have a 200GB hard drive hooked up. If I recall right it was after firmware update.
It is beginning to look like the firmware update that removed support for small (< 16GB) cards has a bug that also blocks bigger drives.
Is it just the VMB4540 that has this issue?
Just another user
For those who are experiencing this issue, could you provide a screenshot of the error message you're seeing?
Hi, of course, but french version with a usb key.
Chris
Here is what I see. I have a 32GB USB drive connected to the SmartHub.
Thank you for the screenshot. I've escalated the information here and will provide an update once the development team has investigated this issue.
Hi, I had an answer from Arlo french support , they are working on it but still waiting for a corrective patch.
Hello, I've the same issue, very disappointed by Arlo, my free period has expired and now no more record, only alert. The problem has started the March 31 and I saw a new update the April 30 but no corrective.
Another customer here who's local storage was working fine, and now doesn't work at all. I tried 2 different USB sticks this morning.
I'm disappointed like the other paying customers that this firmware bug has not been resolved.
Otherwise, I really like most of the features and flexibility of this system.
Arlo would be wise during these difficult times to consider some form of retention/rebate offer to it's monthly subscribers.
I have this issue too - trying to connect a 256GB Sandisk SSD, pre-formatted in FAT32.
Says Error: SD card <16 GB.
I've tried a regular 500GB HDD and that works OK. Prefer to use the SSD though.
Have you tried formatting the Sandisk in the hub itself?
I have been having severe issues with a 128GB Sandisk. It ended up completely messed up. I resorted to a hub reformat. I'll see how it pans out.
Just another user
It doesn't give me the option with that error message - won't even allow you to turn on local storage.
Thanks for the quick reply though.
