Cannot open Arlo App from my Iphone 11 Pro Max
I updated yesterday with fingers crossed to IOS 13.7 and the app 2.19.2 worked fine but I never had the problems other have had since the original 2.19 update. Mabey try rebooting the phone. I have seen a new app may be released next week so hope it addresses the IOS update also if that brings other problems.
AJ24,
What happens when you try to open the app? Are you getting an error?
When I tap the Arlo app to open, it just blinks and won't open.
AJ24,
A new version of the iOS mobile app is available from the app store. Please make sure you have the latest version downloaded and test again to see if you experience the same behavior.
I have the same problem. When I try to open the app, it just blinks.
No, no help so far what so ever
