Hello,
I set up Arlo Pro 3 by using my laptop.
I also set up 2 step authentication on my laptop with SMS and email.
Then I log in on the Arlo app on my iPhone.
It raised an error that:
1. "Oops, An error has occurred. Try again"
I also try to choose another authentication.
However, there is no choice of Trusted This Device.
2. I tried to log in by using code sent by SMS and email.
It is also the same.
Please help me with this.
Hi phanthanhtrung8,
Try reinstalling the Arlo app and rebooting your iPhone to see if that helps. Are you also able to log in through the web client on your computer?
I tried few devices.
I believed that this issue happens because of account setting or logic development of the Arlo authentication function.
Could you check it?
I have the same error.
Do you have any solution?
I reset my ipad and iphone.
Even I chose factory setting.
I believe that this happens because of app and my account.
It is not the reason about my mobile phone or ipad
I'd suggest for you to contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
How did you guys fix it? I have the same problem in Vietnam.
It should be in Account->Profile->Login Settings->Two-Step Verification
Click on "add another method" and you should see an option to "trust this device".
I don't think your answer is relevant to the problem (see previous posts).
Having the same issue here, and in VN as well. Is this due to location issue. It is so annoyed. Please advise or fix. It always shows error message if I enter code for verification but works ok in pc
