Hi all, the app of my pro3 camera keeps on displaying "firmware update available"
So i manually update the camera for multiple times, i even tried removing the camera from the app and reinstall it again. However, it still says “firmware update available " .
That's very frustrating as i spent almost 2 hours on this issue. Has anyone come across this issue?
JKNg,
Make sure the camera is fully charged and has good signal strength, allow it to sit overnight and it should automatically install the update. Are you still experiencing an issue?
I am having same issue with 1 camera. The other 3 are fine. I will bring it inside close to the hub and see. Will
keep u posted. System is only 2.5 yrs old. Updates are the biggest problem the past year
Hi
It has been 3 days already,and the problem hasnt been fixed. The camera display kept on showing "firmware update available"
I am so frustrated! What's wrong with that?
I am in HK
