Local Recordings Not Available in Library
  • 4 Replies
  • 3116 Views
ericjohnson1313
All of a sudden my video recordings are not available in my local storage library.  This is for all cameras and doorbell.  I have rebooted, reset, etc and nothing is allowing the recordings to be seen in library.  When i remove the USB device and check on computer they are all on there but just cant view them in app.  Any ideas?
ericjohnson1313
Thanks for the replies everyone...yes it is local (not cloud) and wasn't showing up for some reason all of a sudden.  I ended up deleting the app, removing the cameras, rebooting the phone, and re-setting up everything and it appears to be working now.  I appreciate the help!
Reboot the phone and reinstall the app.
ericjohnson1313,
For content to be viewable from the Arlo library, you must have a subscription to Arlo Smart. Do you have an active Arlo Smart subscription?
dcfox1
@JamesC wrote:
ericjohnson1313,
Did something change that you need a sub for Local storage viewing in the App with a Smart Hub? He was talking about Local unless he is confusing it with Cloud.
ericjohnson1313
  • 4 Replies
  • 3117 Views
