planIdnullnot found in SubscriptionPlanMapping Cache
Hi
When trying to subscribe to a deal for a plan from an Arlo email I get the following error at the checkout page.
"planIdnullnot found in SubscriptionPlanMapping Cache"
Any ideas what this might be about?
arlopro3jersey,
Was this a promotional email? Could you provide a screenshot of the details?
Any solution to this problem? I am unable to add any subscription whatsoever... could it be to do with my location which is Jersey and not mainland UK?
arlopro3jersey,
I've escalated this to the dev team for further investigation. I will provide an update once I know more.
I received this same message upon login to my account. Would like to know what conditions trigger it.
NWCarlo,
There was a cloud release that resulted in a temporary issue with subscription plans. This should now be resolved, are you still experiencing an issue when attempting to subscribe?
I'm still experiencing the same problem and always have...
I am no longer experiencing the issue. In my case I think it had to do with moving cameras from one account to another. A factory reset of the cameras and base station cleared it up.
arlopro3jersey,
A fix for this has been released, please try again and let us know if you are still experiencing the same behavior.
Same error here trying to cancel my plan.
lund0529,
Are you trying to cancel using the web client or the mobile app? Do you still experience the same behavior if you try today?
Either. Behavior is the same on Chrome/Edge/Firefox on two different computers and the Android app. Cache cleared, rebooted, all updates current, no change.
It does still happen today.
If I try to add a CVR plan, no cameras are selectable.
Trying to change my plan, the "Change Plan" button does nothing on the comparison screen.
Trying to cancel my plan, I get "planIdnullnot found in SubscriptionPlanMapping Cache" in a drop-down orange bar, or nothing happens at all. My unused credit and refund total are shown as $NaN on the cancel summary page.
Developer Console in Chrome shows a lot of Javascript errors.
lund0529,
I see you already have a support ticket open on this issue. I will escalate your support ticket and request a status update.
Probably about 5-6 by now... they just keep asking for screenshots, promise 24-48hr turnaround, and then go dark. I really just want to cancel everything and start with a fresh/clean config, but I can't and nobody in live chat seems willing or able to do so.
Thanks James.
lund0529,
I've escalated this to the development team. It appears there is a bug causing this behavior but I do not have an ETA for resolution. I will provide an update once I know more.
