  • 8 Replies
  • 1060 Views
  • 6 In Conversation
FR8638
Have changed Ethernet wire,  have disconnected from internet, and restarted many times.  Chats have not resolved.  Have not uninstalled as yet. Equipment 3 years old.  System down for several days.  Any further suggestions.
8 REPLIES 8
ShayneS
Hi @FR8638
Were you able to reach out to the support team? Did you happen to have a case number?
djgrif
I have same hardware and same problem. I too have tried everything except a reset. Have you found a resolution to the problem?  Thank you for any help!
ShayneS
@djgrif
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support through the Arlo Mobile App by navigating to Settings/System/Support.
OneStopDecals
Remove the hub from your account and then re-add it - worked for me.
DJArlo
When you remove/re-add the Hub, did you lose all of your connected devices/cameras, custom camera and Mode settings, and local storage library recordings (via the app)?
You don't lose the local recordings (you would have to set that up again, however) but everything else would be as if you just installed the system new.
DJArlo
Well, the question is whether I would still access the recordings from the App Library. If I delete/re-add the device, will the app still associate the camera with its previous recordings?
You previously asked if the local storage recordings would be lost and I answered that. You're now asking if cloud recordings would be lost to which the answer is no, they will not be lost since the system tracks them by serial number of the camera.
  • 8 Replies
  • 1061 Views
  • 6 In Conversation
