Arlo Pro 3 going offline? server outage currently?
If you're experiencing your Pro 3 camera showing offline follow these steps to recover the device:
1.) Power cycle the SmartHub (detach both the ethernet cable and power cable, wait 1 minute before plugging in the ethernet cable first, and power cable second).
2.) Make sure the Pro 3 cameras are blinking blue LED, if not, press the sync button for 1-2 seconds and release for the LED to start blinking.
3.) Start the onboarding process by going through the add a device (Pro 3) and follow the flow until it connects.
If you're still experiencing an issue, make sure the camera is fully charged and factory reset following these instructions: https://kb.arlo.com/000062438/How-do-I-factory-reset-and-re-sync-my-Arlo-camera
After the reset is complete, follow steps 2 and 3 to re-onboard.
