I have change phones and downloaded the app.
I can get video and sound when checking on things manually but no video in library.
I do get sound.
How do I fix this? I've put my new phone as a trusted device
It's not an app/phone problem but perhaps a subscription has expired. Verify that the camera has a subscription since one is required for cloud recordings.
Also, to be clear, you are logging in as the primary user and not as a guest, correct?
@Sandynz wrote:I can get video and sound when checking on things manually but no video in library.
I do get sound.
You get recordings with sound, but the video is black??? That's not a subscription issue.
What do you see using a PC (my.arlo.com)
If you use only local recording, then try connecting the storage to the PC, and check if there is any video there.
