Got "CVR is currently disabled" error message for not connecting to AC power?
Hello, New subscription but getting the following error. Battery is full and it is connected to power.
App, I do not see that issue though browser but the camera is also not recoding at all. Why?
Are you using the outdoor charging cable, or the indoor one to supply power?
You need the outdoor (9 volt) charger for this with the floodlight.
Outdoor.
@Plank22 wrote:
Outdoor.
Are you seeing the normal lightning bolt on the battery icon?
Was CVR ever working correctly with the camera?
I do not see the lighting bolt on this camera. All others yes. No just signed up for the service on this camera
If no lightning bolt in the battery icon, the charger isn't connected or is faulty. Try wiping the contacts on both the cable and the camera and then try wiggling the connector as it snaps into place. Ya gotta have that lightning bolt for CVR to work.
How can that be if the battery is at 100%?
Ah, the icons seem to have changed over time with a full battery not showing a connection. You might want to test this by disconnecting power and triggering a bunch of recordings and live viewing so the battery depletes some. Then connect power again to verify.
In addition, check Settings, Subscription to verify that the camera is actually enabled for CVR.
Use the mobile app.
This still is not working. What 9 volt charger do I need and cable? Part numbers please
- https://www.arlo.com/en-us/accessories/VMA5600C-100NAS.html
- https://www.arlo.com/en-us/accessories/VMA5601C-100NAS.html
The charger is integrated into the cable. The end of the part number (the NAS bit) might be different if you are not in North America.
