  • 12 Replies
  • 2567 Views
Plank22
Hello, New subscription but getting the following error. Battery is full and it is connected to power.
Got "CVR is currently disabled" error message for not connecting to AC power?
12 REPLIES 12
Dannybear
What app are you using when you get the error message, arlo mobile app or using the arlo web portal in pc browser?
Plank22
App, I do not see that issue though browser but the camera is also not recoding at all. Why?
Are you using the outdoor charging cable, or the indoor one to supply power?
You need the outdoor (9 volt) charger for this with the floodlight.
Plank22
Outdoor.
@Plank22 wrote:
Outdoor.
Are you seeing the normal lightning bolt on the battery icon?
Was CVR ever working correctly with the camera?
Plank22
I do not see the lighting bolt on this camera. All others yes. No just signed up for the service on this camera
If no lightning bolt in the battery icon, the charger isn't connected or is faulty. Try wiping the contacts on both the cable and the camera and then try wiggling the connector as it snaps into place. Ya gotta have that lightning bolt for CVR to work.
Plank22
How can that be if the battery is at 100%?
Ah, the icons seem to have changed over time with a full battery not showing a connection. You might want to test this by disconnecting power and triggering a bunch of recordings and live viewing so the battery depletes some. Then connect power again to verify.
In addition, check Settings, Subscription to verify that the camera is actually enabled for CVR.
Dannybear
Don’t rely on the arlo web app for battery status icons or percentages, it has issues.
Use the mobile app.
Plank22
This still is not working. What 9 volt charger do I need and cable? Part numbers please
The charger is integrated into the cable.  The end of the part number (the NAS bit) might be different if you are not in North America.
  • 12 Replies
  • 2568 Views
