Arlo Pro 3 Camera Blue Tint
  • 7 Replies
  • 2512 Views
lcman
I purchased a Pro 3 camera to add into my current Pro 2 VMB4000r3.  The screen is blue tint in day time but normal at night.  Please advise on how to fix it.
7 REPLIES 7
Could be a hardware issue but did you remove the plastic sheet over the front of the camera before installing?
lcman
I did remove the sheet before installation.  And I have reset the camera twice but no change.
K80Shooter
Virtuoso
Virtuoso
@lcman  I would suggest you open a case for support. You could ask @JamesC if he has any other suggestions.
Icman,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
lcman
I reviewed the recorded footage from my Pro 3 camera.  It is flicker (blue tint and normal) instead of blue tint consistently.
I have submitted the case to Arlo Support and look forward to their response.
lcman
I received a email for the case and submitted the information via the link.  Shall I receive an email with confirmation of case update?  If not, shall I resubmit the response again?
lcman,
An agent will reach out to you with an update once the information you submitted is reviewed.
  • 7 Replies
  • 2513 Views
