Setting Up Port Forwarding with Asus RT-AC88U Router
Greetings,
Just got my Arlo Pro 3 kit.
I am trying to set up port forwarding on my router. I have an Asus RT-AC88U.
I got local storage setup using a 32GB USB Drive. No issues there.
Reading that to view local storage at remote location, I need to enable port forwarding. I found where to set up port forwarding on the Arlo hub using the iPhone app. It provides my internal IP address ... which I set as a static IP address on the router ... and an internal and external port number (18831 for both).
My question is what am I then to do on the Asus router. On the router Port Forwarding menu it has a radio button to enable port forwarding and several fields asking for the following info. If someone could tell me what to type into the fields I would greatly appreciate the help.
Thanks.
Steve
RaisingArizona,
For assistance with setting up port forwarding on your router, I encourage you to contact Asus support and speak with an expert.
