  • 6 Replies
  • 6194 Views
huttler
Arlo Pro3s come with a 5V 2.0 amp charger. Why won’t an after market charger with the same rating charge the camera? The camera battery only needs 4.4v to charge (as printed on the battery).
Even my old rotten Pro1s that require a 9v charger (7.2v battery) will work with other chargers as long as they’re rated at 9v 1.8amp
6 REPLIES 6
Don't know if an after market charger will work,... not sure if there is some sort of sense unit in camera for "their" charger.
The more current just makes the charger a bit faster.
You would just have to try the 3rd party charger.
As to the old Pro1 charger with 9v... They used a dual voltage qualcom type charger for that camera. ( puts out 5 and 9v )
The battery will not charge on a standard 5v usb charger with battery at 7.2v ( needing at least 8.4 or so to charge fully )
This was later changed in the P2( and newer ) to just 5v with circuitry in the camera.
jsaus63304
Luminary
Luminary
I am using a 25 foot charging cable with a 3rd party charger on an outdoor camera.  It has worked just fine.  I have charged with it and am using now as a continuous power source.
huttler
Good to know. Can you refer what brand you used?
jsaus63304
Luminary
Luminary
I bought theses from Amazon
25ft/7.6m Weatherproof Outdoor Charging Cable with Quick Charge Adapter
huttler
Thanks! That's a pretty good deal
michaelkenward
Sensei Sensei
Sensei
Same here.
I have used various third party adapters (fast and slow) to power and charge different versions of Arlo cameras.
Just another user
  • 6 Replies
  • 6195 Views
