  • 13 Replies
  • 12246 Views
theconnect81022
Hello,
I have granted access to another user to see my devices. That user has accepted the invite, but no cameras are showing in the feed/dashboard.
FYI:
  • The added user has the new interface on their Apple phone.
  • I have the old interface on my laptop browser and Android mobile phone.
  • I tried reinstalling the apps on both phones and sending access to the new users. Once accepted, still no cameras.
  • Also, the users have been given rights to the cameras.
  • Please see the attached screenshots.
Any suggestions or ideas that could help?
Thanks!
@theconnect81022 wrote:
Hello,
FYI:
You need to migrate your interface to feed.  Note there are bugs and limitations with Feed at the moment, and unfortunately you cannot revert back to the old interface after you migrate.
The workaround to force migration is to go into "add device", and then add either a Pro 5s camera or a home security system.  Of course that will fail, because you don't own either.  But the process will migrate you to feed.
13 REPLIES 13
Hello,
FYI:
theconnect81022
This worked! Thank you!
Tjb2019
I have arlo pro 2 and same issue.  But use received the notifications of movement,  but can't see cameras
If your account shows "Library" as a menu option, and the friend's account shows "Feed", then you need to migrate your account to "Feed".  My earlier post on this thread tells you how to do that.
Tjb2019
I don't know where to see that and his app does nothing and is telling him to add cameras..  like he is a brand new user.     No one wise had to do that
No rocket science involved. Just look at the main screen of the app.
See if yours has choices for "Dashboard" and "Feed" or whether it has a choice for "Library".  Then check the main screen of his account.
Odds are, you are seeing "Library" while he is seeing "Feed".  If that's the case, you need to use the workaround I posted above - migrating your account to "Feed".
Tjb2019
I don't know where to see that when I open the app. I see my cameras settings settings doesn't offer anything like that so where is that
Sigh...  Menu choices are at the bottom of the main app screen.
Here's a screen shot with Feed (my cameras are blacked out):
And here is "Library":
Tjb2019
Tjb2019
I just uploaded a screenshot I don't have that
I don't know what you mean by "that".  But your screenshot clearly shows Library.
The next step is to confirm that the added user sees "Feed".
Tjb2019
 hesees this
@Tjb2019 wrote:
 he sees this
Which clearly shows "Feed".
So you do need to migrate your account to use "Feed".  There are some bugs and limitations with Feed, and you cannot go back to Library if you don't like it.
The process is to use "add device" on your app/account, and then start to add a Pro 5s camera or a Home Security system.  That will fail, because you don't have one of those devices.   But the process will convert your user interface to "Feed".
  • 13 Replies
  • 12247 Views
