  • 5 Replies
  • 1710 Views
JehovasFitness
Luminary
Luminary
Floodlight will randomly come on. Not only that, now last night it was super windy so I set to disarm mode which usually works.
Nope. Ok, so I go into settings and turn BOTH floodlights off.
Nope. Woke up to 40 notifications on each and one not plugged in drained 60% of the battery.
5 REPLIES 5
If connected to a base or hub, reboot that. If connected to WiFi, reboot the individual cameras.
JehovasFitness
Luminary
Luminary
did all that. Clearly there is a firmware issue
JehovasFitness,
Are you using the default "disarmed" mode or are you using a custom mode? Is this still happening?
JehovasFitness
Luminary
Luminary
Default disarmed mode.
That said, it seemed to be an issue that night. Still running into issue of whenever I open the app the lights come on w/o any motion or turning on myself. Just opening the app.
That and randomly coming on and staying on.
Omaroo
I have exactly the same issue...
Most of the time I do not want to have the flood light turning on but it still does even if the settings say it is disabled...
Very annoying and frustrating.... Any help or advice?
  • 5 Replies
  • 1711 Views
