Can I use Floodlight drill holes for Outdoor Security Mount
  • 2 Replies
  • 1431 Views
klasmeister
Hello, I just bought and installed the Pro 3 Floodlight for my front door. After playing around for a bit, I came to the conclusion that it would actually work much better in the garden and I would like to order a smaller camera such as the Pro 2 or Ultra for the front. Does anybody know whether the drill holes for mounting the Pro 3 Floodlight would also work for the Outdoor Security Mount so I don't need to drill new holes? Thanks so much in advance for any help on this!!
klasmeister,
This should be possible as the Arlo Outdoor Security mount uses 3 similar sized screws as the Arlo Pro 3 Floodlight for mounting.
klasmeister,
klasmeister
Thanks so much, James!
  • 2 Replies
  • 1432 Views
