  • 1898 Views
joyvuu-dave
Is CRV available for the Arlo Pro 3 Floodlight? When I click "Subscribe Now" in the CRV Plan box on the settings page says "Select a CVR plan for your camera" but there are no options -- the rest of the page is blank.
My camera is connected to the outdoor charging cable.
joyvuu-dave
Answering my own question, it appears from the documentation that CRV is supported when the floodlight is paired with a Smart Hub or base station. My assumption is that once I do this, I will have options on the subscription page.
Seems like this info is something that could be added to the UI.
joyvuu-dave
Indigo17
I think you also need to be plugged into an electric socket. I don't think you can CRV with just the battery or solar panel
dcfox1
Yes you are correct. AC power only.
  • 1899 Views
