Opening App Turns on Pro 3 Floodlight?
Situation:
Pro3 Floodlight is on Ultra smarthub always in armed mode.
Most of my other cams are on old base station that I set to arm at night before bed.
Past week or so I've noticed when I open the app to arm the old base station, simply just opening the app triggers the Pro3 Floodlight and the synced security lights to turn on.
Never did this before and first few times I just assumed it was because motion triggered them, but I realized last night it happens soon as I open the mobile app.
NeillEvans,
Which app are you using, iOS or Android?
Does this happen every time you open the app?
Arlo Pro 3 Floodlight
