Is CRV available for the Arlo Pro 3 Floodlight? When I click "Subscribe Now" in the CRV Plan box on the settings page says "Select a CVR plan for your camera" but there are no options -- the rest of the page is blank.
My camera is connected to the outdoor charging cable.
Answering my own question, it appears from the documentation that CRV is supported when the floodlight is paired with a Smart Hub or base station. My assumption is that once I do this, I will have options on the subscription page.
Seems like this info is something that could be added to the UI.
I think you also need to be plugged into an electric socket. I don't think you can CRV with just the battery or solar panel
Yes you are correct. AC power only.
