- English
- Floodlights
- Arlo Pro 3 Floodlight
- Arlo lights not turning on with motion in the pitc...
Arlo lights not turning on with motion in the pitch black dark with motion detection set to 100
First - the forum shows this issue multiple times and listed as CLOSED but NO Answers are provided. So, I am opening a NEW discussion in pure frustration. I am ready to return my lights, such a huge waste of time.
They are only lights. They have no camera. I followed set up as instructed. 2 of 3 lights work fine. 3rd light does not work. The light that does not work is located inside a dark area with no access to any other light and it is located 10 feet from the hub. Motion tests work find. Range to hub works fine.
I can only assume the light is broken and I need to return it. Why am I supposed to be my own technical expert here? No technical support? Nice, Arlo saves money by wasting my time.
Can anyone else tell that I am frustrated? Is anyone else tired of solving Arlo product problems for them for FREE?
Have you swapped lights around to see if it's the light or location?
