  • 4 Replies
  • 2209 Views
kulwantd
Hi
my ios app is not discovering vmb4540 base station and i have tried all the troubleshooting options
Should i get a new basestation ?
what are my options.
kulwantd,
A blue LED indicates the base is receiving an internet connection. Are you able to try onboarding using a PC connected to the same network to see if you still experience the same behavior?
kulwantd,
Could you provide more details about what you're seeing? What LED behaviors are seen on the SmartHub?
Have you tried factory resetting before onboarding?
https://kb.arlo.com/1057976/How-can-I-reset-my-Arlo-SmartHub-or-base-station-to-the-default-values
kulwantd
Hello JamesC
Yes, I tried all the options:
1. changing the connection cable
2. Rebooting the basestation
3. Resetting to factory setup
First I see blinking orange LED, then it goes to Blue
Looks like the base station is gone bad.
 A few days before this happened my arlo pro 3 cameras were going offline
should I get new base station VMB4540 ?
Or is there any other option ?
kulwantd,
kulwantd
Through PC it worked but I had to do factory reset.
Thank you.
  • 4 Replies
  • 2210 Views
