  • 5 Replies
  • 6690 Views
Edouglas01
How do I go back and see recordings that have been moved to iCloud storage?
michaelkenward
Sensei Sensei
Sensei
That's what I thought. So the answer is to use whatever put the files on the iCloud, if that really is where the files reside rather than Arlo's own cloud.
Just another user
5 REPLIES 5
michaelkenward
Sensei Sensei
Sensei
How did they get moved to iCloud?
Just another user
The only way to get them into any other cloud service is to download them yourself and place them into your cloud service. The Arlo cloud is not iCloud or any other service.
michaelkenward
Sensei Sensei
Sensei
Just another user
Edouglas01
The arlo 2 system is new. Once you’ve seen the recording then choose to delete it where does it go? How are you able to go back and see it again after it’s deleted from your smartphone if at all?
First, I recommend never deleting a video since there are too many requests to get them back and you can't. When it's deleted, it's deleted. If you've downoaded the video to your phone or computer then it's a different procedure. Using the app on the phone doesn't delete it from your phone, it deletes it from your account on the servers.
  • 5 Replies
  • 6691 Views
