  • 1 Reply
  • 1512 Views
Rbgreenwood
Can someone tell me what it means when the dual battery charger has one green light that’s constant and one amber light is flashing on top of the battery docking station??????
Haven't seen that but it sounds like either a bad battery or charger. What happens if you swap the batteries around - does the same LED flash amber?
  • 1 Reply
  • 1513 Views
