I keep getting this message operation cannot be completed at this time does anyone know what this means
Over the past month, no video playback and getting message "The operation could not be completed"
I have seen other posts but not seeing that anything is being done to fix it.
Without being able to see the playback, I am missing what is causing the activation.
We have 2 bases, one with 4 cameras and one with 2 cameras. Playback on the one with 2 cameras seems to be working find but can't get playback on the 4-camera system.
What has happened over the past month? Can someone help, please?
I still get that message every once in awhile. I don’t think it’s an issue with the cameras. It’s Arlo firmware updates. Now the quality of videos are bad too. I’ve done nothing different or changed anything.
Once in awhile a library video will play but most of time not.
Why is the only support a community email chat voicing our frustrations?
Does anyone have a phone number for Arlo Support/Customer Service?
2 cameras
iPhone 7
As well as the Operation could not be completed;
Recording times for both cameras are erratic even though I have customised them both in the Edit Mode through the App(the app has been deleted and reinstalled many times)
As previously reported when recording is small I’m unable to replay video, this is the same as other reports in that the problem is intermittent but I’m also having instances where people are recorded walking up the path of my house but not recorded when they leave?
Sometimes the recording stops when they are halfway up the path?
Same problem... started mid-May and gives same error message mentioned in this string. Re-booted but no improvement. What is the problem / solution Arlo?
For me they seem to happen when the base station is about to fall over which is not as often either. Base station must be almost fixed by now with all the naps it has had.
We have been getting the "Operation cannot be coompleted at this time" messages on and off for at least a month. Has anyone found a resolution? We have reset the system, that did not work. Also, what is the point of a security camera if it won't play the video? That's a safety issue. This occurs on the App ALOT, but if we can hook up to a computer (not always possible) we can sometimes see the video.
Arlo customer services # is 408-638-3750. I called about this issue on May 30; spoke to a customer service agent who acknowledge that Arlo was aware of this problem and that engineers were working on it. He assigned me a case # and assured me he'd follow up with an email so I could follow the progress and know when the issue was resolved. Thankfully I asked for the case # on the phone, as I never received that email. He also told me I'd be informed of the fix (somehow) when I logged into my account, but I don't see anything like that available. I haven't had the time to call back to follow up, but I continue to have the same issue: Unable to view recorded videos. Length doesn't matter. Camera doesn't matter. Some days I can view ~50% of videos; some days ~10%. My cameras are 4,000 miles away, purportedly protecting our vacation house. But they're failing miserably, as everyone on this thread knows. It would be really nice if Arlo cared about its long-term customers...
And to clarify, the message I'm receiving is "The operation could not be completed." (no "at this time.") Are there two different error messages, or are people just indicating it incorrectly?
You ask a very good question.
The four error messages I regularly get are:
1. The operation cannot be completed. Got it.
2. The operation couldn’t be completed. (Cocoa error -1.)
3. The requested URL could not be found on this server. Got it.
4. There was an error obtaining you library. The Arlo team is working on this issue.
The first two are related to the bad recordings on the cloud.
The third is because arlo delete the faulty recordings before you can notice them missing.
The last, only the gods know what arlo is up to.
Perhaps there was a patch, but I think it was an adjustment I made. I tweaked my video recording settings from 15 to 20 seconds. The next recording successfully played with sounds using iPhone app.
We’ll see if it stays this way. We use a metered internet at this remote cabin so 20 seconds isn’t ideal. We’ll probably roll it shorter to see what happens.
Perhaps this is an option for others.
I have both Arlo Pro and Arlo Pro 2 cameras operating on Arlo Pro 2 base stations. My Arlo Pro 2 cameras are all working fine but get a message ‘the operation could not be completed’
’Got it’ I have an iPhone Xs on iOS 12.3.1 some videos play once and then don’t work at all other times they just don’t work at all. Mainly happening at night on my Arlo Pro camera. I have the same message on 2 different iPads as well.
’Got it’ I have an iPhone Xs on iOS 12.3.1 some videos play once and then don’t work but most other times they just don’t work at all. Mainly happening at night on my Arlo Pro camera. I have the same message on 2 different iPads as well.
Can you tell me where/how you changed that setting re the length of your videos? I'm not seeing it in the app. Thanks.
To set your video length, go to Mode>Armed>select your camera>Record video. You'll see the length option there.
For me, all videos under 15s or so won't play. The longer ones play. All of them play when I watch them through Google Chrome on my pc.
Thanks, KK619. My current setting is to record until motion stops. If I change the length of the video, that means they will ALL be a fixed length, no matter if the motion goes on for awhile--is that right? If so, it seems like a unsatisfactory alternative. Or maybe I'm missing something? But then again, the entire situation is unsatisfactory, and we users should not be trying to jury-rig a work-around to a product that is failing in its sole mission.
problem as well as other picture related problems surfing safari. Do android users also experience this ?
Is everyone who
One thing I noticed tonight is that on a video that gives the operation not completed error when you play back the video in chrome it has a loud burst of audio white noise at the beginning of the video that gives the error. The videos that do not have the error do not have the noise burst. Somehow the video is getting the audio track corrupted in the first second and may be causing the error for the IOS app.
Apple specifications for playback identify this and hence why they won’t play or download to their devices.
This issue has been occurring well before the last two firmware base updates and since it has been reported that it also affects Arlo Baby cameras it places the issue squarely on the arlo recording server.
Arlo can’t be helped.
