  • 6 Replies
  • 5400 Views
  • 5 In Conversation
Shizwiz
Just got a 4 camera Arlo 2 Pro setup last night and for the first ~3 hours it was great, recordings would appear in my library whenever a motion alert fired.  Then they just stopped appear, nothing I did would bring them back but I kept getting motion alerts.  I restarted the device, logged out of the app, re-installed the app nothing.
I was getting ready to box it up and return it and tried one more setting: I changed the recording duration from ""Record until activity stops" to "Record for a fixed length" and now it works again.  It seems that no recordings were made because "until activity stops" never recorded long enough of a "duration".  Is this a problem because of recording lag, ie I motion/activity happens for 6 seconds but there is 6 seconds of lag before a recording starts so by the time it decides to record something there is nothing to record?
Note: I'm using the iOS App (not a browser)
6 REPLIES 6
dl_foster
I started having the 'no recording' issue a couple of days ago. One of my outside cameras was picking up motion too often, so I set up activity zones. Once that was done, there were no recordings happening. I deleted the activity zones, and now I am getting recording again.
ShayneS
Hi @Shizwiz
Have you tried to adjust your sensitivity or positioning for the cameras? I have provided an article her with more detailed information. How do I position my Arlo wire-free camera?
Shizwiz
Thanks for the suggestions! I don’t have any activity zones setup on my cameras as they’re not connected to power so they can’t use them. As far a sensitivity goes I get alerts on my phone that “motion is detected” so it does detect motion it’s just no recordings are shown in my library (unless I specify a manual recording duration).
ShayneS
Have you tried to remove the cameras from the Settings > My devices > Re-add them?
Seam
I have two Arlo Pro 2 cameras and 3 older model cameras. The recordings are not showing up in the library on my phone with the two Arlo Pro 2 cameras. I have deleted activity zones, reset the base station, removed and re-loaded the app and re-synced the cameras. I am returning the two cameras.
Do the cameras have rules in your modes? After deleting and resyncing them, custom modes need to have rules re-entered. The Armed mode gets them automatically - have you tried using that mode?
  • 6 Replies
  • 5401 Views
  • 5 In Conversation
