The image quality I have with Pro 2 cameras is much worse than other "1080p" devices. Grainy, blocky, pixillated, pulsing. Especially bad when green things (e.g. grass, leaves) are in the frame. When I first got the system I recall the image quality to be better. Perhaps Arlo downgraded image quality in order to gain bandwidth for other things, such as two way talk. Anyone else notice this?
AFAIK, they've actually reduced the compression to improve the video quality. Maybe it went backwards again? I don't seem to be having any issues with my Pro2 cameras
Not much going on til later when a vehicle passes but the video looks pretty good to me
https://arlo.netgear.com/hmsweb/users/library/share/link/6A7234A082793585_201806
Yep, I have noticed the same thing and have had Pro 2 cameras for about a year. Image quality used to be waaaay better and is now downgraded to junk for many users.
They have screwed up something with the update or done it purposely for the reasons you mentioned, who knows.
Very disappointed with the video/image quality as well and the whole system. Used to be satisfied customer for quite some time, but not any more. Very poor image quality pisses me off. Not even close to 1080p as falsely advertised on the product. Nothing wrong with the hardware, but poor firmware makes this system useless.
Can you post an example screenshot of the image quality you are describing?
This camera has a connection to database with 3 of 3 bars. Used to be clear and crisp. Have the same problem after may firmware update with all the 3 cameras I have had for a year now.
Your phone camera also has many more pixels (1080p is 2 megapixels) and there's big difference in the typical compression used. Also, the Arlo cameras are very wide angle compared to the phone so fewer pixels trying to be used over a wider view leads to less quality.
HD ain't.
The same has happened to Arlo pro. Used to get crisp images now bellow HD quality and poor battery life. One the cameras have given up the ghost going back to wired alternatives. Images are of better quality and less battery hassle (even with solar charger). Paying for a wired system in the long term is a better alternative as quality is better there is a time stamp and less image issues at night.
Not fit for purpose outside and night vision poor and for a premium priced product a poor show
