The app used to allow me to set one camera to begin recording when motion triggered another camera. That option seems gone in the current Android app but I have 1 camera that only records when camera 2 is triggered. How do I reset camera 1?
Also, I used to be able to change the sensitivity of the motion sensors. That option is gone too. So am I just stuck with what I've got?
Both options are still there.
Have you looked into the mode and rule(s) you are using for the cameras? https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
@ME23 wrote:
Rules are gone too.
Can you create a new mode?
