  • 4 Replies
  • 3209 Views
ME23
The app used to allow me to set one camera to begin recording when motion triggered another camera. That option seems gone in the current Android app but I have 1 camera that only records when camera 2 is triggered. How do I reset camera 1?
Also, I used to be able to change the sensitivity of the motion sensors. That option is gone too. So am I just stuck with what I've got?
Both options are still there.
Have you looked into the mode and rule(s) you are using for the cameras? https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
ME23
Rules are gone too.
@ME23 wrote:
Rules are gone too.
Can you create a new mode?
ME23
Thanks, yall! I found the rules.screen and think I got it fixed. Mode was the one place I didn't look.
  • 4 Replies
  • 3210 Views
