I switched to a pixel 7 & cannot view live in full screen. I followed the previous solutions by clearing cashe & storage, no dice. I uninstalled the app & tried again, clearing cashe again, still no dice. When I click on the full screen &/or tilt my phone, the live camera quits. I can only view upright, small screen.
Do you see Library to view recordings or Feed? I suspect Library since you're using a Pro 2.
I just tested using a Q camera (same vintage and resolution) with the new UI (Feed) and there is a double-headed arrow to go to full screen on a Pixel 6. It may be a difference between the camera model and/or UI so I can't be sure I see the same thing as you.
I'm in the library & there are no recordings & no double headed arrows, I have to go back to the live feed to attempt full screen.
Can you try again and see if it is now working?
It's still the same unfortunately
