  • 6 Replies
  • 2076 Views
Warehamd
I switched to a pixel 7 & cannot view live in full screen. I followed the previous solutions by clearing cashe & storage, no dice. I uninstalled the app & tried again, clearing cashe again, still no dice. When I click on the full screen &/or tilt my phone, the live camera quits. I can only view upright, small screen.
6 REPLIES 6
Do you see Library to view recordings or Feed? I suspect Library since you're using a Pro 2.
I just tested using a Q camera (same vintage and resolution) with the new UI (Feed) and there is a double-headed arrow to go to full screen on a Pixel 6. It may be a difference between the camera model and/or UI so I can't be sure I see the same thing as you.
Warehamd
I'm in the library & there are no recordings & no double headed arrows, I have to go back to the live feed to attempt full screen.
Tagging the mods since it sounds like an app issue with the old UI.
@JamesC , @ShayneS , @BrookeN
BrookeN
Can you try again and see if it is now working?
Warehamd
It's still the same unfortunately
goochhobbit
I having the same issue on a pixel 7a and have tried the same solutions as suggested previously but nothing has worked  i have a Arlo Baby
  • 6 Replies
  • 2077 Views
