Doesn't seem worse, either. I think it connects the app and browser look together better.
@jguerdatwrote:Doesn't seem worse, either. I think it connects the app and browser look together better.
What do you think about the forced password re-enter/finger-print scan every time accessing the app. Liked the android app a lot better before, when you only had to do it once after app installed. What a pain it is now, it’s certainly reducing my number of times accessing it every day.
I don't have to do that. Yes, if you have fingerprint access turned on you'll have to do that every time but it's always been that way (at least as long as I've had a fingerprint-capable device). If you turn that off, you get auto-login. It's working for me that way in both the app and browser unless I do something from another device that logs the first device off.
@jguerdatwrote:
I don't have to do that. Yes, if you have fingerprint access turned on you'll have to do that every time but it's always been that way (at least as long as I've had a fingerprint-capable device)..........
I know it was like that already with the iPad, but not with android phone. That’s the app they just updated and it now requires either password or fingerprint scan. I had been using my android phone (with fingerprint access turned on) for a long time and never had to do that until a few days ago, right after the update. That was part of the reason I preferred accessing the app on phone. No big deal.....just have to get used to it. Really like all other features they’ve introduced.
Maybe I'm being dense but I have only Android devices and don't have to enter the password to access the app. I have used the fingerprint feature but turned it off since it requires the fingerprint every time. Using the password-only method allows me to use the app with no need to enter anything - it just goes to the Devices tab.
Are you saying that you have to enter the password every time if fingerprint is turned off? If so, I'd try reinstalling the app and rebooting the phone.
I get autologin with my S7 Edge. I don't really see a need for fingerprint access given I need to use my fingerprint to unlock the phone first anyway. I'd get annoyed if I needed to input the password every time since it's 18 characters long
Yeah that was it, had to reinstall the app but also rebooted the phone. It’s working ok now! Thanks.
