Motion Detection Notifications Arriving Too Late. How should the sensitivity be adjusted?
I have a 300ft driveway and my camera is only recording about 3 seconds of the car just passing the camera. How should the sensitivity be adjusted to pickup the vehicle sooner. Also the notifications are slow to reaching my cell and at times people have come and gone before I'm notified.
Hi 4Rock,
To adjust the motion sensitivity, feel free to read this article: How do I change the motion sensitivity on my Arlo camera?
And if you're receiving your push notifications late, try to optimize your motion detection on your camera to see if that helps. You can read more about it here: How do I optimize motion detection for my Arlo camera?
Hi Unknown-,
If you're experiencing the problem where your videos are delaying, try rebooting your Base Station to see if that helps.
Have you tried changing the motion sensitivity on your Arlo camera or optimizing the motion detection for your camera? You can see the links above to see if that helps.
