I just purchased a new iPhone and I keep receiving the unable to add trusted device error. I thought this was resolved months ago. The device is completely new, not reloaded from iCloud and I made a unique name for it as well so there is no duplication.
There was an update that should help with this issue. Please try updating your devices to the latest version of the Arlo Secure iOS app v4.3
Note: If you do not see the update you can try removing and re-installing the app.
Hey Jdavis03
I just escalated your case & someone from support will be reaching out to you as soon as possible. I have provided your escalations number here: 43124524
I recently upgraded to an iPhone 14. My account is a friend on Arlo. When I log into Arlo I receive a message that Arlo does not recognize my device. When I select a different device it still shows my iPhone 11. I’ve deleted and reinstalled the app more times than I can count. I rebooted the phone several times. My husband deleted me as a user and reinvited me several times. Very frustrating
Can you provide a screenshot of the error message. Do you have the latest version of the Arlo app and iOS on your device?
OS is 16.0.2
i upgraded from An iPhone 11 to a 14
I assume I have the latest Arlo version. I’ve deleted and reinstalled the app several times
screen shot below. Also when I select another method, the iPhone 11 shows up and not the 14
This has been resolved. We reached out to Arlo tech support. Thank you
Thanks for the update.
Have same issue with my new iPhone 14pro. Please advise!
@Amieb918
May I ask which troubleshooting steps you have performed so far? I don't want to suggest anything you have previously performed.
I have deleted the app and downloaded new, changed password, refreshed browser, cleared cookies, restarted device. I can’t sign into my Arlo on my computer either, says same thing, so I can’t go there to access more help. Have done all they requested on chat.
@Amieb918
This is a newly added phone correct?
Yes got it yesterday, iPhone 14Pro
Have you tried the "Try another verification method" option?
How did you get number for Tech support ? Please help !
You need a subscription for phone support. The normal process is to go into the subscription area of the app, select a subscribed camera (doesn't matter which one). Scroll down to "Contact" and you'll see a phone option.
Don't google for a phone number, that doesn't work (and almost always leads to a scam support site).
What specific problem(s) are you having?
I'm having the same issue.
@MPDamon
Are you still experiencing this?
Do you happen to have a screenshot of the error message?
I have the same issue, and this is how it looks like. iOS 16.1.2 is my current operating system.
I am having the same issue for iPhone 14 Pro. iOS 16.1.2
The original post was 2 days ago and Arlo team was just investigating today.
Purchased a new iPad Pro and get a message from Arlo, “Add trusted device”. When I click on TRUST a message appears on my iPad that states, " There was a problem trusting this device, Try again”. Keep getting the same message over and over. Thanks
Hi,
When will it be fixed? I can't view my security footages from my phone. This is a blocker. Is that possible I can downgrade my app?
Can you login by selecting don't trust?
