  • 2 Replies
  • 1020 Views
NCSF
I just want notifications/alerts on one camera only and not all of them. Currently it's either all or none. Can you update the firmware to allow alerts for each camera individually?
If you have a subscription, you can already do this.  Go into the smart notifications setting.  You can then select each camera and disable some (or all) of the smart notifications for it.
If you want to disable both notifications and recordings, you can create a custom mode that only has a rule for the desired camera, and use that mode. https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
dcfox1
@NCSF  If you are using the default "armed mode" you can go to to rules for the cams you don't want and select "do nothing" for recordings if you do not want them and uncheck notifications and save. I have done that sometimes without creating a separate custom mode if you want.
  • 2 Replies
  • 1021 Views
