HOW DO I KEEP VIDEO INDEFINATELY? IS THERE A WAY SO THEY DON'T ERASE
HOW DO I KEEP VIDEO RECORDINGS INDEFINATELY? THERE ARE CERTAIN ONES I NEED TO SAVE?
Yes - download them.
I APPRECIATE YOUR REPLY TO MY QUESTION. THANK YOU
HOWEVER...I AM CLUELESS AS TO HOW TO DOWNLOAD. CAN YOU PLEASE OFFER DETAIL INSTRUCTIONS IF YOU HAVE TIME? I DON'T KNOW IF I NEED A DIFFERENT PLAN I HAVE TRIED DOWNLOAD FROM PHONE & I GET MSG" I NEED TO ALLOW ACCESS TO STORAGE TO DOWNLOAD MEDIA. HOW IS THIS DONE?"
BTW I ALWAYS TYPE IN CAPS...I AM NOT YELLING...THANK YOU FOR UNDERSTANDING
It would be nice etiquette to NOT use caps. It's actually harder to read.
Use the library tab and either select a video or view it and use the download selection (you may need to use the 3 dot menu selection to see this). You also need to have all permissions in the phone settings for the app allowed so access is allowed to save the file. How you do this depends on whether you're on iOS or Android.
