  • 5 Replies
  • 2488 Views
omez99
Hi I have three Arlo Pro 2 cameras and just added the Arlo doorbell, took advantage of the Ring tradein deal.
As I was adding the doorbell, I also added the solar panel/chargers to two of my Arlo Pro 2 cameras, because they are in difficult to reach locations when batteries would die.
The solar chargers are working great, with both cameras remaining at 100% charge since I installed them.  However, the night vision views and recordings are now very poor quality.  Previously, all three Arlo Pro 2's had acceptable night quality.
Now of the three the one without the solar charger added is the only one with decent night quality.
I searched a bit and find references to hazy quality so verified the following:
1) the cameras have not been moved at all, nor do they appear dirty.  In fact I cleaned them when charging them up prior to adding the solar chargers, and then placed them back exactly where they were before.
2) I've verified the settings on all three Arlo Pro 2's are exactly the same
Any ideas out there?... before I make the climb to disconnect the solar on one of them to see if the issue goes away..
I'd rather not as that was the reason to add the solar to begin with, to avoid having to keep going up where they are.  Thanks in advance for any help.
5 REPLIES 5
Make sure however the solar panel is , it is not reflecting the night time IR illumination...
anything to close to the cameras ir and it will bounce back and wash out picture
omez99
Thanks @TomMac, but they are pretty far from the cameras, not at all in their line of sight.
Are you using skins on the cameras? The hood sometimes causes reflection of the IR LEDs.
omez99
nope
omez99
I’m out of town at moment but next time I have a chance will climb up and try and adjust to see if can come to a conclusion. Thanks all.
  • 5 Replies
  • 2489 Views
