I cannot get a USB Drive to format on my Arlo Pro Base Station VMB4000r3 (firmware 1.20.3.0_4203_8). I have tried several drives and formatted FAT32. Any ideas?
Are the drives at least 16GB? SMaller ones are now incompatible.
Yes, 64GB - 250GB
Can you provide a screen shot of the Storage Settings Menu
Are you able to to format the drive via a pc?
May I ask which troubleshooting steps you have performed so far? I don't want to suggest anything you have previously performed.
I can format the drive via PC. I have formatted in both exFAT and FAT32.
It MUST be FAT32 - exFAT won't work. What size drives are they? Need to be at least 16GB.
250GB
It's been a while but I believe the VMB4000 had 2 USB ports - have you tried both?
Yes, I have tried both ports.
Are you still experiencing this?
Yes
Is it possible got check with a new drive, formatting via the pc again first?
I have tried three. I'm giving up and will just upgrade my system.
I can escalate this for you if you like?
