  • 5 Replies
  • 1863 Views
  • 2 Likes
  • 5 In Conversation
kasnh
Another issue I'm having.
The cameras were set to record at 'Fixed length of Time' to 60s and was working fine for a  day but today I get recordings short or more than 60s. What is happening?!?!? I've power cycled my base and it still does this! No, I have not reseated the batteries on the cameras, I refuse to. This things should be a "set it and forget it" devices and not to monitor the security cameras 24/7 if they're working or not!
5 REPLIES 5
Dannybear
The last camera firmware update released awhile back added an additional content stream to the recording and the base station does not work well because of it.
Try rebooting the base to see if that helps.
crocker
I have the same problem! I have 5 camera's all set with a fixed recording time of 40 seconds each. Now when motion is triggered the recording times vary wildly. Sometimes recordings are only 14 seconds or 7 seconds or whatever seconds.
I have rebooted the base station by switching it off and also pulling the plug. I have also tried deleting and re-syncing one camera and that did not correct the problem.
This problem seems to coincide with the recent base station update.
I hope Arlo fixes the problem soon?
I really don't want to reset my base station!!
ShayneS
@crocker Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
crocker
Thank you for the link!  As I am still having issues, I will reach out to customer support.
  • 5 Replies
  • 1864 Views
  • 2 Likes
  • 5 In Conversation
