I have tried multiple troubleshooting suggestions (reset wifi channel, move unit away from modem, restart, reset...) and nothing works. My base station is continually flashing amber, which supposedly means it's offline, yet I am able to connect to the cameras via the app on both my phone and my desktop computer. It does seems to take a very long time to connect, ~15 seconds. A thief would be up and long gone before I even knew he was there. I just really want to know if it's ok that the base station continually flashes amber.
Did you look at the link above? The blinking amber LED means a weak signal to a camera. Moving the base and/or camera for a better connection will fix this. Use the WiFi icons for each camera to help determine which one is weakest.
Since you seem to have the VMB4000, which has 3 LEDs for power, Internet and Camera, which one is flashing amber? If you have a newer model base with 1 LED that should be blue but is flashing amber, what model is it?
From the FAQs in the support section here (along with many other topics):
https://kb.arlo.com/000039100/What-do-the-LEDs-on-my-Arlo-SmartHub-or-base-station-mean
I have the VMB4500 base station with one LED, flashing amber. I do not notice any disfunction other than the flashing amber light. All cameras connect.
Sorry, no I hadn't looked at the link. It appears that three out of four of my cameras have weak signals. I think I will just move the base station so that I can't see the flashing light... thank you for your answer!
