Why is my camera detecting motion when I have selected that to be off? I just want it to pick up humans and autos.
Hi X Navy,
when you say detecting motion, do you mean your are receiving notifications on your lock screen or there are motion recordings in your library?
Additionally, to clarify, do you have a smart subscription?
It is normal that it is going to record all motion detection events to your cloud library.
Though, if you are having issues of not receiving just smart notifications for people, etc. I would toggle off smart notifications for that camera, wait 30 minutes and then toggle it back on.
That has helped me and others here in the past.
Thanks!
It will record everything to library with smart notifications but not send a notification for unselected options.
@Xnavyman17 Are you using activity zones, that is different from smart notifications. You never answered previous question from a another poster here asking you if you have a smart notification subscription active.
@Xnavyman17 Yes It will and always did record every thing even it was off in smart notifications but not give a notification if off. Your not giving alot of details here so its hard to help. What are your smart notification settings. Are the recordings outside your activity zone? Those you should not get. Some have reported problems with that.
Any input would be appreciated.
