  • 5 Replies
  • 2404 Views
bu74n3
I just bought the Arlo Pro 2 with 3+1 cameras and one of the batteries is showing a full charged icon but the power % stays at 0% regardless how long I plug in the USB charger (see attached screenshot). I put this battery into another camera and the same thing happens...does that mean the battery is dead?
5 REPLIES 5
You could try and power button reset of the base... sometimes the battery data doesn't flow
As to the battery, if it operates the camera, its good and just a bad reading.
bu74n3
I am afraid this is not the case...I have plugged in the charger overnight and this morning when I unplugged the charger it tells me that the camera needs charging with 0% left. I have also tried resetting the base.
bu74n3
I did, the issue is not that the battery is not charging -  the battery icon shows that the camera is charging the battery but somehow the battery stays at 0% and goes off when the charger is unplugged. I have tried this battery on another cameras with the same results.
Open a case with support here for a faulty battery.
  • 5 Replies
  • 2405 Views
