The entire point of having cameras is to protect my property--esp at night. Is there any way to improve the video? Will lightening/brightness have any effect??
The IR LEDs on the Pro2 are good out to about max 20 ft ( pir is good to a max of 25ft )...
IR lighting runs on the inverse sq law... light falls off quickly for distance
can you post shots?
yes, any external lighting can help
No shots to post, I deleted them. You literally cant see anything but fog.
Highly disappointed in this camera.
Daylight, the video us great. At night, it's worthless.
here's a pro2 night shot...
small stump in center is 25 ft away or so cam is 6ft high
here's last night ...raccoon ( not as sharp )
Can you compare to other cameras?
Or contact Arlo support for possible warranty
I have an Arlo Pro on another property, the night vision is excellent. The pro 2, at least on mine, is nonexistent.
It may, but prob not... test it
the Pro , IMO, has always been better in the dark over the P2
you mentioned fog in a previous post. Is there anything close to the camera. Reflection for IR light can be very bright off of anything close including the wall or guttering.
so i just installed my Pro 2 outside and at night its horrible, its dark and its grey. I walked back there and still cant see much. When i toggle the night vision on and off it looks exactly the same. this sucks.. I have an Arlo Q inside and i can see everything great and clear in middle of the night...
just hooked mine up outside and same exact issue.. pissed off. I have a Q inside the house and when it is pitch dark it looks amazing.. customer service wants me to send photos but what good is that going to do? from the forums here it appears its a design flaw
Brightness makes zero difference, and strangly enough, when i toggle the night vision off on my phone the picture looks exactly the same...no difference
how close to gutter downspout will not be an issue? I just see grey fog as well but my camera is mounted roughly 8 inches from the gutter
i have no covers on my camera, its naked... and its all grey and washed out still
i threw away the boxes already
The Pro has much better night vision. What good is a security camera that cant be used in the dark. I'll sacrifice some other options to have night vision.
Hi @elykoj
Have yo tried to reboot your camera or remove & re-sync it to your base station? The Arlo Q does not sync directly to the base station, but it will appear within your account on the web & mobile app as it currently does.
