  • 56 Replies
  • 6437 Views
  • 13 In Conversation
Ronin8793
My arlo pro 2 night vision is terrible. It records, but the video is so dark, it's useless. Is this typical?
The entire point of having cameras is to protect my property--esp at night. Is there any way to improve the video? Will lightening/brightness have any effect??
56 REPLIES 56
The IR LEDs on the Pro2 are good out to about max 20 ft ( pir is good to a max of 25ft )...
IR lighting runs on the inverse sq law... light falls off quickly for distance
can you post shots?
yes, any external lighting can help
Ronin8793
20 feet? I'd be good with that. But every night video is a fog. You cant see anything.
No shots to post, I deleted them. You literally cant see anything but fog.
Highly disappointed in this camera.
Daylight, the video us great. At night, it's worthless.
here's a pro2 night shot...
small stump in center is 25 ft away or so cam is 6ft high
Ronin8793
I'm not getting that good of a video. I'd be thrilled with that quality. It's seriously nothing but fog.
here's last night ...raccoon ( not as sharp )
Can you compare to other cameras?
Or contact Arlo support for possible warranty
Ronin8793
Does adjusting the brightness level make a difference?
I have an Arlo Pro on another property, the night vision is excellent. The pro 2, at least on mine, is nonexistent.
It may, but prob not... test it
the Pro , IMO, has always been better in the dark over the P2
Monkey_501
you mentioned fog in a previous post. Is there anything close to the camera. Reflection for IR light can be very bright off of anything close including the wall or guttering.
Ronin8793
No. There's nothing in the kens--i checked. My saying "fog" was meant to mean I saw nothing on the video but the IR "darkness".
USMC4EVA
So as a fairly new owner of Arlo Pro 2 ( never owned any other models) when I first installed the cameras the night vision was useless as seen in the picture. Browsing around this forums I came to the conclusion that it was possible that the silicon covers might had something to do with the bad night vision. Needless to say, the silicon covers were covering the IR lights making the image foggy and completely useless. I cut off all the excess silicon that was in the front of the camera and my night vision works great now.
Iss
I am getting the same problem on one of my cameras after the latest firmware update.
elykoj
so i just installed my Pro 2 outside and at night its horrible, its dark and its grey. I walked back there and still cant see much. When i toggle the night vision on and off it looks exactly the same. this sucks.. I have an Arlo Q inside and i can see everything great and clear in middle of the night...
elykoj
just hooked mine up outside and same exact issue.. pissed off. I have a Q inside the house and when it is pitch dark it looks amazing.. customer service wants me to send photos but what good is that going to do? from the forums here it appears its a design flaw
elykoj
Brightness makes zero difference, and strangly enough, when i toggle the night vision off on my phone the picture looks exactly the same...no difference
elykoj
how close to gutter downspout will not be an issue? I just see grey fog as well but my camera is mounted roughly 8 inches from the gutter
elykoj
i have no covers on my camera, its naked... and its all grey and washed out still
Ronin8793
Do what I did. Return the Pro 2. And get the Pro model. The night vision is much better.
elykoj
i threw away the boxes already
Ronin8793
Depending on where you bought the camera, that may not be a problem.
elykoj
Best Buy. But what would I buy in its place ? I would downgrade options with the Pro and I’m sure they won’t exchange with an Ultra as it’s a different base. If I got the Ultra, would my Indoor Q sync up with it too?
Ronin8793
I know nothing about Ultra.
The Pro has much better night vision. What good is a security camera that cant be used in the dark. I'll sacrifice some other options to have night vision.
ShayneS
Hi @elykoj
Have yo tried to reboot your camera or remove & re-sync it to your base station? The Arlo Q does not sync directly to the base station, but it will appear within your account on the web & mobile app as it currently does.
elykoj
Yes I’ve tried all those suggested options and none helped.
  • 56 Replies
  • 6438 Views
